DAQmx folder in \vi.lib\ missing
I am trying to run DAQmx vis on a fresh installation of LV2014 SP1 (DAQmx Drivers 14.5.1) but the installation does not create the DAQmx folder in the vi.lib so my VIs (developed on a different machine) cannot find the required DAQmx VIs. I also have an installation of LV2015 on the same computer where the DAQmx drivers are installed and working (and the folder in the vi.lib also exists). Any suggestions on how to get the drivers working on my LV2014 installation?
(7,399 Views)
You need to install drivers after you install LabVIEW. Did you do that?
(7,396 Views)
Yes, I downloaded the drivers fresh from NI today, installed them, rebooted but I don't see the folder in the vi.lib. LV installation is about a week old.
(7,393 Views)
Repair your installation of NI-DAQmx and make sure that support for LabVIEW 2014 is selected when it is being installed.
(7,385 Views)
Solution was to install the 2015 driver package again and rebooting. Thanks
(7,379 Views)
Accepted by fgeldmacher
The key is to remember is that NI drivers will detect what programs you have installed.
If you install a new version of LabVIEW after NI-DAQmx, you must repair the NI-DAQmx installation so that it can detect that you now have new version LabVIEW and therefore install the drivers it needs.
(7,377 Views)
