01-27-2015 08:14 AM
I want to send a signal on my NI USB-6009 using the NI-DAQmx C implementation. I want to sent a continuous signal and implement this function in Python 3. For this, I first tried the example of scipy cookbook, which I adapted
First I try to use the this example, but I always get the error -200220: 'Device identifier is invalid.' when calling DAQmxCreateAOVoltageChan, even though the device is listed as "Dev1" in Ni MAX.
Solved! Go to Solution.
01-27-2015 08:36 AM
I got the error on myself:
The error is the wrong assignment of the device: In Python 3, to hand over the physicalChannel property, the string has to be in bytes. Hence a quick fix to
self.CHK(nidaq.DAQmxCreateAOVoltageChan( self.taskHandle, b"Dev1/ao0", "", float64(-10.0), float64(10.0), DAQmx_Val_Volts, None))
solves the problem
