Multifunction DAQ
DAQmxGetWriteSpaceAvail always give me 0 Space Avail
I try to set up a buffer for my AO. Then I can write the chunk of the big file into the buffer.But when I use the DAQmxGetWriteSpaceAvail, the availabel space is always 0.
I am calling library in Matlab.
Here is my code.
AOBuffer_Size=10000;
AOHalfBuf_Size=AOBuffer_Size/2;
AOBufferSpaceAvail=uint32(0);
while
[a]=calllib(
(counter<=10)'myni','DAQmxGetWriteSpaceAvail',taskSlaveAO,AOBufferSpaceAvail_ptr)
end
[a]=calllib(
'myni','DAQmxWriteAnalogF64',taskSlaveAO,5000,0,10,DAQmx_Val_GroupByScanNumber,A_ptr,empty_ptr,reserved)
end
fclose(fid);
If someone can give explanation about my problem, I appreciate.
[a]=calllib('myni','DAQmxCfgOutputBuffer',taskSlaveAO,AOBuffer_Size)
[a]=calllib('myni','DAQmxSetWriteRegenMode',taskSlaveAO,DAQmx_Val_DoNotAllowRegen)
AOBufferSpaceAvail_ptr=libpointer('uint32Ptr',AOBufferSpaceAvail)empty_ptr=libpointer('int32Ptr',0);reserved=libpointer('uint32Ptr',[]);
fid=fopen('C:\zhou\PhysDataAcq_v2.02\SquareWaveNew.dat','r');
A=fread(fid,[1,AOHalfBuf_Size],'double');
A_ptr=libpointer('doublePtr',A);
[a]=calllib('myni','DAQmxWriteAnalogF64',taskSlaveAO,5000,0,10,DAQmx_Val_GroupByScanNumber,A_ptr,empty_ptr,reserved)
[a]=calllib('myni','DAQmxStartTask',taskMasterDO)
[a]=calllib('myni','DAQmxStartTask',taskSlaveAO)
[a]=calllib('myni','DAQmxStartTask',taskDev1CO)
counter=1;
if (AOBufferSpaceAvail>AOHalfBuf_Size)
counter=counter+1;
while
Message 1 of 16
(4,064 Views)
I am setting up a buffer for my AO. So I can write a chunk of a big file into the buffer.
But when  I execute the DAQmxGetWriteSpaceAvail, I always got availabe space equals to 0.
Here is my code. I am calling library in Matlab.
end
[a]=calllib(
end
fclose(fid);
If someone knows the solution,please let me know!
Thanks!
AOBufferSpaceAvail_ptr=libpointer('uint32Ptr',AOBufferSpaceAvail);
counter=1;
while (counter<=10)
[a]=calllib('myni','DAQmxGetWriteSpaceAvail',taskSlaveAO,AOBufferSpaceAvail_ptr)
AOBufferSpaceAvail
counter=counter+1;
Message 2 of 16
(4,061 Views)
Sorry for posting my question too many times. But the codes always cannot show up correctly.
I attach in the attachment this time.
Message 3 of 16
(4,060 Views)
Hi zhoulmnk-
     I wonder which version of NI-DAQmx you are using.  A very similar issue was reported with NI-DAQmx version 9.0.2 using an X-Series MultifunctionDAQ card to R&D, and we fixed it on the very next release of NI-DAQmx.  The most recent version of NI-DAQmx is version 9.2.3, found here.
     This issue was originally reported in this discussion forum post.  I would go ahead and download NI-DAQmx 9.2.3, and then let us know if the issue still persists.  Thanks!
Gary P.
Message 4 of 16
(4,031 Views)
Hi zhoulmnk-
Gary P.
Message 5 of 16
(4,031 Views)
Hi Gary,
Thank you for reply.
Actually I am using version 9.2.3. The problem is still there. But my matlab version is pretty old. It is R2006a.
liming
Message 6 of 16
(4,027 Views)
What DAQ card are you using?  I don't see that you mentioned that.
Zach Hindes
NI R&D
Message 7 of 16
(4,008 Views)
I am using PCI 6221 right now.Thank you!
liming
Message 8 of 16
(3,990 Views)
Hi zhoulmnk-
     Take a look at this discussion forum post.  It discusses disabling regeneration in order to use the DAQmxGetWriteSpaceAvail function.  Let us know if this helps the issue.
Gary P.
Message 9 of 16
(3,973 Views)
I already saw this post and disable the regeneration. The problem is still there.
I attached my codes to see if anyone can find the problem in my codes.
Thank you!
liming
Message 10 of 16
(3,953 Views)
