02-08-2010 01:29 PM
I have a Windows CE 5.0 system with a C# (.NET) application running on it. I need to add some basic data aquistion like that provided by the NI USB-6008 OEM (analog input, encoder input).
Is the NI-DAQmx Base driver compatible with CE 5.0?
Does this driver support C# application development or is it for "LabView only"?
If the answer is "no" on either of the above questions, is there another approach that you'd recommend.
Thanks for your help!
- Mark
02-09-2010 01:09 PM
02-09-2010 01:12 PM
