Display db data in graph
Hi everyone, i'm trying to import data from database and display it in graph. database output will be in variant. I want it to show the data in graph. I think it need some conversion, i'm struggling here in conversion, i attached vi upto till i did and also attached the pic of data i'm getting from database. Please help me to get the data in graph.
(2,653 Views)
You should be able to just use Variant To Data to convert directly into a floating point.  But do you know what the actual data type in the variant is (SGL, DBL, etc)?
GCentral
(2,642 Views)
I earlier used variant to data node but sometimes it displays an error "unsupported data format" that's why i moved to trying another nodes. And another main problem i'm facing that, I written query to read the data in descending order , it accept the query but still it displays ascending order data. Can you share me where i'm making mistake?.
This is the query i'm using to read the data    "select * from NImeter order by datecreated desc"
Thanks for your response.
(2,640 Views)
That tells me there was an error in your reading of the database.  Either the data stored was a different data type than you expected or there was no entry and you therefore got an empty variant returned.
GCentral
(2,637 Views)
Thank you sir, Now i'm able to see the data in graph but still the descending order query is not working , as well as in graph it shows wrong time, Can you tell me how to synchronize graph time and system time.
(2,634 Views)
@praveenrajk wrote:  Can you tell me how to synchronize graph time and system time.
Have your DAQ/Simulator output a waveform and the T0 will tell the chart what time to put in the x-axis.
GCentral
(2,621 Views)
