Multifunction DAQ
Do I need DAQmx Timing in my DAQ solution?
Hi all,
I use my USB-6000 I/O to acquire two analog signals coming from a temperature and humidity sensor. I continuously check if the temperature is above the user limit and I use an indicator to show this overheating.
The SubVI called multiple_sensors.vi acquires the two analog signals but I do not use the DAQmx Timing.vi to do that because I only need one sample of both signals each time I run the SubVI and this happens when the state "Acquisition" is active in the state machine.
The VI works fine but I wonder if I should use the DAQmx Timing.vi in my DAQ because it is always used in the NI DAQmx solutions.
Can you tell me if I should use the DAQmx Timing in my DAQ?
Thank You!
(2,449 Views)
Accepted by jesLVbcn
If you are doing the 1 sample on demand, you do not need the DAQmx Timing.  But if you want to capture waveforms, you do need to use the DAQmx Timing.
GCentral
(2,420 Views)
Thank You!
(2,407 Views)
