03-06-2018 07:22 AM
Hi all,
I use my USB-6000 I/O to acquire two analog signals coming from a temperature and humidity sensor. I continuously check if the temperature is above the user limit and I use an indicator to show this overheating.
The SubVI called multiple_sensors.vi acquires the two analog signals but I do not use the DAQmx Timing.vi to do that because I only need one sample of both signals each time I run the SubVI and this happens when the state "Acquisition" is active in the state machine.
The VI works fine but I wonder if I should use the DAQmx Timing.vi in my DAQ because it is always used in the NI DAQmx solutions.
Can you tell me if I should use the DAQmx Timing in my DAQ?
Thank You!
Solved! Go to Solution.
03-06-2018 10:15 AM
If you are doing the 1 sample on demand, you do not need the DAQmx Timing. But if you want to capture waveforms, you do need to use the DAQmx Timing.
03-06-2018 02:39 PM
Thank You!
