12-18-2008 08:02 AM
Solved! Go to Solution.
12-18-2008 10:52 AM
Hi umutozkan...
Thanks for the post and I hope your well today.
Firstly you'll need either the MATLAB® Data Acquisition Toolbox, which can be used with NI-DAQmx. OR Simulation Interface Toolkit (SIT) which default generates DAQmx VIs to communicate with the DAQ board. It seems for your post your using Matlab, so option 1.
The Data Acquisition Toolbox version 2.12 supports DAQ hardware that uses either the NI-DAQmx or Traditional NI-DAQ driver software. MATLAB supports NI-DAQmx version 8.5 or higher and Traditional NI-DAQ version 7.3 using this toolbox.
The Data Acquisition Toolbox 2.8 version was made specifically
to work with NI-DAQmx 7.5 and Traditional NI-DAQ 7.3. The older
versions of the Data Acquisition Toolbox for MATLAB® supported earlier
versions of Traditional NI-DAQ only.
IThe Mathworks, Inc. website has the most updated support information
regarding NI-DAQmx.
All see this long forum post,
Use M-Series cards with DAQmx in Matlab!
http://forums.ni.com/ni/board/message?board.id=250&message.id=10165
I hope this helps,
12-22-2008 06:42 AM
12-23-2008 06:53 AM
Hi umutozkan,
Any device supported by MATLAB's Data Acquisition Toolbox can also be use in Simulink.
The list of National Instruments devices supported by Data Acquisition Toolbox is here
http://www.mathworks.com/products/daq/supportedio14005.html
If you don't see your device search for it by name in the search box on the top right of The MathWorks web site as often support for a new device can be added between official MATLAB releases by a simple edit to a text file. If you still don't see the device fill out the request form at the bottom of that web page.
Regarding using Simulink with DAQ devices, there is quite a bit of documentation on using Data Acquisition Toolbox in Simulink. Here are some suggested starting points:
General introduction:
http://www.mathworks.com/products/daq/simulink
Demo page:
http://www.mathworks.com/products/daq/demos.html?show=demo at the bottom.
Webinar page
http://www.mathworks.com/products/daq/demos.html?show=recorded
Documentation:
http://www.mathworks.com/access/helpdesk/help/toolbox/daq/bqufxdv.html
Hope this helps.
12-07-2009 03:37 AM
hi: may i ask you a question. I want use the daq to get the data for the simulink and do the real-time research, all things have been done but when i run the labview there is a error:Requested value is not a supported value for this property! how i solve this problem? thank you so much!
12-08-2009 10:47 AM
Dan King
12-09-2009 01:06 AM
http://forums.ni.com/ni/board/message?board.id=250&thread.id=54115
would you please look at this two pitcture for me, the problem is like this. thank you so much!
12-09-2009 06:08 PM
Dan King
12-10-2009 07:45 AM
12-11-2009 12:38 PM
Dan King
