07-20-2007 09:07 AM
07-23-2007 05:07 PM
Hi FlipTek,
Thank you for posting on the National Instruments forum.
You don’t need a voltage divider before measuring the data because the analog range is -10v to 10v and the output of your sensor is TTL, so it can be read by our digital inputs or the analog inputs. Are you using digital acquisition for reading the signal?
This might also be an issue for you if you are acquiring at low speeds.
Why Do I Get Error -200284 When I Set a Small Sampling Rate in DAQmx?
A good resource is going to http://www.ni.com/ and doing a search for your error number on the top right. That will bring up several knowledge base articles or tutorials for whatever issue you are searching.
07-23-2007 09:06 PM
06-17-2010 04:22 PM
06-18-2010 05:04 PM
Hi s-p,
Have you tried all of the troubleshooting steps in the this KB? The error is a DAQmx driver error, which means that we are most likely not setting up the task correct. What language are you using to program your DAQmx task? What DAQ device are you using?
06-19-2010 01:27 AM
Hi Ryan
i Tried but they didnt work.please say me how to set up the DAQmx for counting input and frequency?my DAQ board is USB-6229 M series.and i dont know what you mean by language for programming DAQmx.i just used one of the samples for counting input and frequency which has been posted in this forum and one form example finder
06-19-2010 11:40 PM
two wires are coming out of the Tachometer ,i changed their connection ,i mean i connected another one as ground and then the error vanished .but i'm still getting some data which are not the actual frequencies.any help?
06-19-2010 11:59 PM
even when i turn the tachometer power off .i still get these data.
06-21-2010 04:08 PM
Hi s-p,
If you are receiving values when the tachometer is off then it sounds like you are getting the frequencies of the noise around you. Have you checked the output of the tachometer with a multimeter to make sure that it is outputting the correct values? I assume that you are using LabVIEW as your programming language, so what examples are you trying to use?
