Error -200288 occurs while writing to AO channel
I have a usecase where the user can stop the task at any point and write different samples and start again. But I face the below error while trying the same.
Error -200288 occurred at DAQmx Write Error.vi
Possible reason(s):
Attempted to write a sample beyond the final sample generated. The generation has stopped, therefore the sample specified by the combination of position and offset will never be available.
Specify a position and offset which selects a sample up to, but not beyond, the final sample generated. The final sample generated can be determined by querying the total samples generated after a generation has stopped.
Attempted to Write Sample: 0
Property: RelativeTo
Corresponding Value: Current Write Position
Property: Offset
Corresponding Value: 0
Task Name: _unnamedTask<18>
I have noticed that, if I unreserve the task before writing the new samples, the task runs without any issues. Is this the right fix or can this be improved.
(791 Views)
Accepted by BhaghyarajSol
1. Your code ran just fine for me using a simulated device (PCIe-6341) and DAQmx 20.1
2. Stopping the task should have been sufficient without needing an explicit unreserve.  That leads me to 2 speculative thoughts:
  • are you using a USB or network-attached device?  I'm wondering if the little extra latency involved might be getting in the way
  • what if you replace the unreserve with a simple "stall data flow" delay?  Make a front panel control for your delay time so you can easily experiment with different delays.  Try starting with ~200 msec and if that works, keep cutting it in half until you get the error.
    I'm wondering if for your combo of device / driver version, you need to allow just a little extra time for DAQmx to fully manage the Stop even though the function call has returned outputs back to you already.  I know something like this has come up as an issue when trying to reuse a channel immediately after Clearing a task that used it.
3. Having said all that, an explicit "unreserve" should also be a viable workaround.
-Kevin P
ALERT! LabVIEW's subscription-only policy coming to an end (finally!). Permanent license pricing remains WIP. Tread carefully.
(772 Views)
Thanks for the inputs, Kevin.
I tried to simulate the same device (PCIe-6341) and tried my code, still it showed me the same error. Even with stall data flow (tried with 10s max) , still no luck.
One difference I see in my setup is that I have DAQmx 20.7.
Anyway, for now I'm retaining my workaround.
- Raj
(716 Views)
