09-13-2011 02:13 PM
Thanks Seth, Thanks a lot for your help.
Regards
Himanshu Nagpal
09-13-2011 02:52 PM
Hi Seth,
One last question, is there any way in which i can add how many switches you want to use? I want to make program it in a way it is generalise for all cases. If user enters 5 it runs first 5 ports and if choses 32 ports it runs 32 ports or 10 ports it runs logic for 10 ports and ignore rest.
Thank You
Himanshu Nagpal
09-13-2011 03:00 PM
You can use the "Array Subset" function. It will look something like this:
09-16-2011 09:51 AM
Hi Seth,
Sorry, I have a question again. Actually I am trying to write it in a text file and table. I want when it runs first time it write temperature and power meter reading for switch1, switch2, ....(so on) ( which ar nothing port1, 2,.. I have just givn them a name of switch1,2..) untill it reaches no. of ports( in array subset) which we will be using. and then outer for loop works it keep updating under sitch1, switch2,---so on.
I made a logic but what it does is it writes under switch1 and temperature. So can you guide me what can I do here?
Thank You
Regard
Himanshu Nagpal
