Error -89120 while running discrete frequency sweep vi
I am trying to use "Discrete Frequency Sweep (DAQmx).vi" example under Sound and Vibration Toolkit. I am getting -89120 error saying "source terminal to be routed could not be found of this device". I have attached the screenshot of the error along with the front panel. I have also attached the block diagram of the the vi.
In the front panel you can see that I have selected the AO and AI channels (from the possible channels suggested by the code itself). I have used these channels outside of this code and they do indeed work. I have attached screenshot showing MAX recognizing these channels.
I don't know why this example code is not running. What am I missing? Any help is appreciated. I am new to Labview and using Labview 2018. Thanks!
Message 1 of 1
(1,774 Views)
