Multifunction DAQ
External Reference for Analog Output X series?
Hello does the x-series DAQ cards support External Reference for Analog Output?  I'll be using latest LabVIEW, DAQmx and probably the PCIe-6321.  If this card does not support this function, please advise.
(3,167 Views)
Hi rberger,
The 632x does not support using an external reference at all.  Notice in the specifications that it only has a ±10V range available.  The 634x boards likewise do not support using an external reference for Analog Output.
You'll probably want a 635x (e.g. PCIe-6351), which allows you to use the external reference to determine the full scale range of the DAC (see specifications).  The 636x also have this feature and have a faster ADC (notice however that aggregate sample rates are the same on the multiplexed versions of the 635x and 636x if you are using more than a single channel).
The older 628x boards had an additional feature of allowing you to use an external voltage reference as the offset of the DAC.  No X series boards currently exist with this feature, so if this is what you need you'll have to use the 628x (e.g. PCI-6281).
Best Regards,
John Passiak
(3,155 Views)
Thanks for the reply, I will use the PCIe-6351.
(3,131 Views)
