Getting 1055 internal errors when trying to use DAQ Assistant in LabView
I'm trying to do a simple task of aquiring an analog voltage with my PCIe-6351. I am getting 1055 internal errors. The details are in the attached text file. Any help is greatly appreciated.
Wes Z
(2,754 Views)
Hey wesz,
Can you provide a screenshot of your code and the error or the VI itself.  Did the error occur the first time you ran the code or only after you have made some changes to the DAQ Assistant Express VI?  The forum post describes another possibility that may be occuring as you graph the data:http://forums.ni.com/t5/LabVIEW/Error-1055-occurred-at-Property-Node-Object-reference-is-invalid/m-p....  Please post back with your code and any additional questions.
Kevin Fort
Principal Software Engineer
NI
(2,742 Views)
