01-30-2007 10:04 AM
01-31-2007 07:32 PM
02-01-2007 09:43 AM
Actually, I am running two 4350/TC-2190 setups over 2 USB interfaces to my laptop (running XP). I set up each device/channel for a T-Type thermocouple. When I go to the Data Neighborhood and look at the virtual channels, they are all there. I can run a test panel on each of the channels and I see the correct data comming in from the TC. However, when I go to the VI Logger task tab, although I have set up all 14 channels to log, many of the channels are greyed out with "No data" next to them. As I said, I have verified that they are working channels by using the test panels, but for some reason I can't get the channels to record data. So yesterday, since I was able to get the 7 of 14 channels working on each of the two units, I decided that 14 total channels was probably good enough. I took the laptop into the lab and restarted the test, and now only two of the 7 channels show data in VI Logger. (All the channels still show correct data when queried with the test panels). I am wondering if there is something I have set up wrong. In addition, I am getting random General Protection Fault errors that cause me to have to restart windows (something about file : NIPALK.SYS causing problems). Not sure the two problems are related.
Chris
02-02-2007 11:23 AM
02-02-2007 11:29 AM
Thanks Abhinav. I am now able to view all the channels! I think I may have solved my other problem. It may have been a result of trying to power two USB ports off of a laptop computer. I have now increased the power supply to the laptop and have not gotten the blue screen error message. Looks like everything is working (for right now). Thanks for your help.
Chris
02-05-2007 10:33 AM
