03-29-2016 12:39 PM
Hi i'm having trouble connecting my digital signal to a case structure. And i'm also having trouble acquring the 3 signals together, 2 analog(thermistor & potentiometer) and one digital(switch). could you help with that? thanks
03-29-2016 02:26 PM
Use Index Array to get the first element in your digital array.
03-29-2016 02:56 PM
I've got problems with the breadboard connection as well, the digital signal which is the switch is acting as an on and off switch for the 2 analog signals. wrong readings when the switch is off & the correct readings when its on. but i want all of them to act independently. how can i do that?
