I am using the PCI6111 to realize an Autotest System for power supply.
Now we have 2 questions about the timing test:
- Can we do the Two-edge separation measurements between the analog input & the digital input?
- Can PCI6111 do the Two-edge separation measurements?
- If the PCI6111 can not use the Two-edge separation measurements Test Function, is there any way we can test the timing between an analog signal & a digital signal.
Thank You
Shawn
nicecx@msn.com
shawn.chen@cherokeepwr.com
