07-14-2011 02:33 PM
How many readings can be stored internally before the device overflows. Any pointers to info which describes this would be appreciated.
Thanks.
07-14-2011 03:17 PM
512 bytes. 256 samples. This is specified in the USB-6008 user manual. Check the specifications section, Analog Input, AI FIFO (page 24).
You can also always determine this programmatically. Create a task of the type you want and query the Onboard Buffer Size from a DAQmx Buffer property node.
07-14-2011 03:37 PM
Ok. I missed that on P24. Thanks.
