Multifunction DAQ
How to change state of the port in .net using NI-DAQmx?
I am playing with NI-DAQ, USB6501, what I am trying to accomplish is write into the Digital output the "state" of each line?
I saw an example for writing the  digital output channels but can't find on how to do the state (high/low).
Anybody?
Thanks!
(2,793 Views)
Hi mbda,
Are you refering to setting the "tristate" property of the channel?
If not, when you create the channel to be a digital output, writing a boolean to the channel indicates the state (TRUE = high, FALSE = low).
Rohan B
(2,774 Views)
