05-17-2010 05:02 PM
I am in the process of converting code for simulataneous analog in and out on the PCI-6111 from VB6 to VB.NET. Is there an example that shows how to route the signals to sychronize input and output on this board? With the traditional DAQ system, I used the RouteSignal function to connect PFI2 to AIConvert.
I put my current DAQmx code below:
Private Sub cmdSetupNIchannels_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdSetupNIchannels.Click
OutTask = New Task("My Out Task")
InTask = New Task("My In Task")
OutTask.AOChannels.CreateVoltageChannel("dev1/ao0", "", OutRangeMin, OutRangeMax, AOVoltageUnits.Volts)
OutTask.AOChannels.CreateVoltageChannel("dev1/ao1", "", OutRangeMin, OutRangeMax, AOVoltageUnits.Volts)
OutTask.Timing.ConfigureSampleClock("", SampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, NumSamples)
InTask.AIChannels.CreateVoltageChannel("dev1/ai0", "", AITerminalConfiguration.Pseudodifferential, InRangeMin, InRangeMax, AIVoltageUnits.Volts)
InTask.Timing.ConfigureSampleClock("", SampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, NumSamples)
End Sub
Private Sub cmdTestNIin_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdTestNIin.Click
InTask.Stop()
OutTask.Stop()
Dim i As Long
Dim writer As AnalogMultiChannelWriter
writer = New AnalogMultiChannelWriter(OutTask.Stream)
Dim dataOutA() As Double
Dim dataOutB() As Double
ReDim dataOutA(NumSamples - 1)
ReDim dataOutB(NumSamples - 1)
For i = 0 To NumSamples - 1 ' put in test waveforms
dataOutA(i) = i / 50000
dataOutB(i) = -1 * (i / 25000)
Next
Dim dataWaveOut(1) As NationalInstruments.AnalogWaveform(Of Double)
dataWaveOut(0) = NationalInstruments.AnalogWaveform(Of Double).FromArray1D(dataOutA)
dataWaveOut(1) = NationalInstruments.AnalogWaveform(Of Double).FromArray1D(dataOutB)
writer.WriteWaveform(False, dataWaveOut)
AddHandler InTask.Done, AddressOf AnalogInFinished
OutTask.Start()
InTask.Start()
End Sub
Private Sub AnalogInFinished()
Dim reader As AnalogSingleChannelReader
reader = New AnalogSingleChannelReader(InTask.Stream)
Dim dataWave = New NationalInstruments.AnalogWaveform(Of Double)(NumSamples)
dataWave = reader.ReadWaveform(NumSamples)
Dim data() As Double
data = dataWave.GetRawData
MsgBox(data(23).ToString) ' for testing purposes
End Sub
Private Sub cmdDisposeNI_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdDisposeNI.Click
InTask.Dispose()
OutTask.Dispose()
End Sub
05-19-2010 06:26 PM
Hi bws,
If you navigate to your National Instruments folder and follow this path, there should be a MultiFunction AIAO Dig Start.vb example in .NET framework. Your .NET might be a different version, but the code will be the same. To view the code you are interested in, right click the MainForm.vb and View Code. Let me know if this helps, thank you!
\National Instruments\NI-DAQ\Examples\DotNET3.5\Synchronization\Multi-Function\SyncAIAO_DigStart\VB
