How to distinguish two USB DAQs connected to the same PC?
I'm now planning to make a system using two USB 6008.
In this case, how can I distinguish two 6008s? I mean, which one becomes "dev1"?
Also, is there any way to fix the assignment of the physical channl name for each device?
If I could read the serial number (or machine id) of each DAQ, it would be helpful...
(I am using VB.NET).
Thanks in advance...
(3,362 Views)
Accepted by ytaku
Dim Devices() As String = NationalInstruments.DAQmx.DaqSystem.Local.Devices
Dim DeviceInfo As NationalInstruments.DAQmx.Device
Dim X As Integer
For X = 0 To Devices.GetUpperBound(0)
DeviceInfo = NationalInstruments.DAQmx.DaqSystem.Local.LoadDevice(Devices(X))
MsgBox(DeviceInfo.DeviceID & " SN = " & DeviceInfo.SerialNumber.ToString)
Next
Make sure to add references to NationalInstruments.Common and NationalInstruments.DAQmx to the project.
There is other information in the DeviceInfo structure that me be helpfull as well
(3,357 Views)
Thank you!! It worked very well!!
(3,340 Views)
