How to generate two analog output with two external sample clock soure
I had a USB 6353 DAQ card and want to used it to generate two analog waveform with different sampling clock sources.
My problem is I can run only one task with one sample clcok source on any channel but had error with two tasks.
Any clue?
(900 Views)
You can't do it the way you're describing.  You *might* be able to get the same end result by approaching things differently.
Your device only has 1 timing engine available for AO, so it can't simultaneously run 2 tasks that use different sample clock timing signals.
Depending on your system & your app requirements, you *might* be able to define both AO output channels in terms of the 1 fastest clock source.  But if not, you would need more DAQ hardware to generate 2 AO tasks with independent sample timing.
-Kevin P
(881 Views)
Thanks Kevin.
(845 Views)
