How to outout two analog voltage at the same time in two analog output channels?
I use the BNC 2110. I want to output two analog voltage at the same time at two analog output chanels. Do I have to use multithreading? And how to do that? Thanks.
Message 1 of 8
(3,290 Views)
The BNC 2110 is a connector block, not a DAQ device.
What type of DAC device are you using and what programming language are you writing with?
Curt
Message 2 of 8
(3,279 Views)
There is a function generation on the board and I use that to generate the signal. I use that to control a microscope.
Message 3 of 8
(3,269 Views)
I don't know if these apply to whatever hardware you're using, but try these examples
C#
http://zone.ni.com/devzone/cda/epd/p/id/1433
http://zone.ni.com/devzone/cda/epd/p/id/1423
Curt
Message 4 of 8
(3,266 Views)
I am using LabWindows CVI.
Message 5 of 8
(3,262 Views)
Actually this does not work on my computer. It just output on one physical channel. What I want is to output on two physical channel.
Message 7 of 8
(3,234 Views)
Hi photoszzt,
I was able to get the example provided by Curt C to output on multiple channels. When selecting the channels in the example to use for analog output make sure to follow these steps:
1. Build and run the application
2. While the application is running press the arrow for physical channels to open the drop-down menu.
3. Press browse in the drop-down menu
4. To select multiple channels, hold the CTRL button and click each channel to be used for analog output
Milan
Message 8 of 8
(3,213 Views)
