How to use an external digital signal to trigger a digital sequence output (USB-6221)
I am using USB-6221 port0 to generate a 8-bit digital sequence. Below is the Python code calling C program.
How to use the PFI0 port to take another digital sequence for triggering the port0 output? How to use the function DAQmxCfgDigEdgeStartTrig?
 daq.DAQmxCreateTask("",taskCounter)
daq.DAQmxCreateCOPulseChanFreq(taskCounter,"Dev1/ctr0","",daq.DAQmx_Val_Hz,daq.DAQmx_Val_Low,0.0,freq,0.50)
daq.DAQmxCfgImplicitTiming(taskCounter,daq.DAQmx_Val_ContSamps,1000)
daq.DAQmxCreateTask("",taskHandle)
daq.DAQmxCreateDOChan(taskHandle,"Dev1/port0/line0:7","",daq.DAQmx_Val_ChanForAllLines)
daq.DAQmxCfgSampClkTiming(taskHandle,"Ctr0InternalOutput",freq,daq.DAQmx_Val_Rising,daq.DAQmx_Val_FiniteSamps,nsamples)
daq.DAQmxWriteDigitalU32(taskHandle,2,0,10.0,cnst.DAQmx_Val_GroupByChannel,startdata,None,None)
daq.DAQmxStartTask(taskHandle)
daq.DAQmxStopTask(taskHandle)
daq.DAQmxWriteDigitalU32(taskHandle,nsamples,0,10.0,cnst.DAQmx_Val_GroupByChannel,idata,None,None)
print("Data Written\n")
daq.DAQmxStartTask(taskCounter)
(1,313 Views)
I simply added the DAQmxCfgDigEdgeStartTrig function, but obviously it doesn't work.
        # Create Digital Channel
        # q = daq.DAQmxRegisterDoneEvent(taskHandle,0,None,None)
        # q = daq.DAQmxRegisterDoneEvent(taskCounter,0,None,None)
        # External trigger
        daq.DAQmxCfgDigEdgeStartTrig(taskHandle,"Dev1/PFI0",daq.DAQmx_Val_Rising)
        # write startup values
        # load trigger sequence
        # start counter
The error is shown below:
b'Specified property is not supported by the device or is not applicable to the task.\nProperty: DAQmx_StartTrig_Type\n\nTask Name: _unnamedTask<5>\n\nStatus Code: -200452'
(1,291 Views)
I am not a python guy, but in general, it should be possible.
I observe that you're using a counter task to be the sample clock for the DO task. Try one step at a time, just set up a DO task with an onboard clock and digital edge trigger.
Santhosh
Soliton Technologies
(1,272 Views)
hi
(947 Views)
@zhm0204 wrote:
hi
Please create a new topic to discuss your requirement, do not hijack other posts to suit your unrelated question.
Santhosh
(927 Views)
