Multifunction DAQ
Installing NI-VISA 4.5.0 in OpenSUSE 11.2 fails
I am trying to use a NI USB 6009 so I am installing NI-VISA 4.5.0 as a prerequisite to DAQmx Base. I get the following error:
Warning: nikali post installation failed! /tmp/nikaliPostInstall.log follows:
And farther down:
./uninstall.sh: line 13: .: Makefile.in: file not found
Uninstalling NI-KAL (nikal): done
/bin/rm -rf objects
Updating NI-KAL:
 NI-KAL update failed.
/bin/cp nikal.c objects/nikal.c
/bin/cp nikal.h objects/nikal.h
make -C /lib/modules/2.6.31.12-0.2-default/source SUBDIRS=/usr/local/natinst/nikal/src/objects modules
make[1]: Entering directory `/usr/src/linux-2.6.31.12-0.2'
  CC [M]  /usr/local/natinst/nikal/src/objects/nikal.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "init_mm" [/usr/local/natinst/nikal/src/objects/nikal.ko] undefined!
  CC      /usr/local/natinst/nikal/src/objects/nikal.mod.o
  LD [M]  /usr/local/natinst/nikal/src/objects/nikal.ko
make[1]: Leaving directory `/usr/src/linux-2.6.31.12-0.2'
Installing NI-KAL (nikal): Starting NI-KAL failed!
make: *** [install] Error 1
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
Some details about my system:
uname -r
rpm -qa |grep ^ni
niorbi-1.9.0-f0.i386
nivisaserver-4.5.0-f0.i386
nimdnsresponder-1.1.0-f2.i386
nivisa-4.5.0-f0.i386
nirpci-4.0.0-f1.i386
nipalki-2.4.0-f0.i386
nivisak-4.5.0-f0.i386
nivisa-config-4.5.0-f0.i386
nicvirte-8.0-7.i386
nidimi-1.9.2-f0.i386
nispyi-2.6.0-f0.i386
nikali-1.9.0-f0.noarch
nipxirmi-1.6.0-f0.i386
nipali-2.4.0-f0.i386
nivisa-devel-4.5.0-f0.i386
lsmod |grep ni
NOTHING?
I am attaching niSystemReport output.
Thank you very much for any help you can provide. After many hours trying different things I've found in the forums I am totally stuck.
(3,295 Views)
I forgot to attach niSystemReport
(3,293 Views)
Hi pcr,
This distribution of Linux is not supported by National Instruments drivers.  Check out the What Linux Distributions Do National Instruments Drivers and Software Support? KnowledgeBase.
Sara Lewandroski
Applications Engineer | National Instruments
(3,271 Views)
Just closing the loop for other searchers and readers: the reason for these errors is in the NI Linux Users Community.
http://decibel.ni.com/content/message/16541#16541
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,251 Views)
