09-24-2010 09:37 AM
What Hardware is needed to interface a Modus ASCII or RTU unit to the PC that has Labview drivers?
Thanks.
Solved! Go to Solution.
09-27-2010 01:22 PM
Hi dbaechtel,
Modbus works through either serial and/or Ethernet, depending on the device that you are working with. The only hardware you need beside the device you're trying to communicate with is a serial card or Ethernet card, both of which are included in most computers. Plus you probably need cables.
09-28-2010 08:46 AM
Thanks.
