06-25-2010 07:53 AM
I have the USB TC-01 thermocouple device. I've installed DAQmx 9 and it is recognised in "Devices and Interfaces". However, the example code supplied is written in Labview 8.1 and I am running 7.0Express - is it possible to run in 7.0 (I can't find a vi to interface with it)? If so, does anyone have example code and/or can convert the example code to 7.0? thanks in advance
Paul
Solved! Go to Solution.
06-25-2010 09:36 AM
The last version of DAQmx for LabVIEW 7.0 is version 8.1. The readme for 9.0 also states that 7.0 is not supported.
Good reason for finally doing a long overdue LabVIEW upgrade.
06-25-2010 10:07 AM
Dennis,
thanks for the info and the quick response - confirms my suspicions!
Paul
