Multifunction DAQ
Is it possible to run the USB TC-01 from Labview 7.0 Express?
I have the USB TC-01 thermocouple device. I've installed DAQmx 9 and it is recognised in "Devices and Interfaces". However, the example code supplied is written in Labview 8.1 and I am running 7.0Express - is it possible to run in 7.0 (I can't find a vi to interface with it)? If so, does anyone have example code and/or can convert the example code to 7.0? thanks in advance
Paul
(3,016 Views)
Accepted by topic author pocdow
The last version of DAQmx for LabVIEW 7.0 is version 8.1. The readme for 9.0 also states that 7.0 is not supported.
Good reason for finally doing a long overdue LabVIEW upgrade.
(3,002 Views)
Dennis,
thanks for the info and the quick response - confirms my suspicions!
Paul
(2,995 Views)
