Multifunction DAQ
LabView Locking up when I try to use NI9485 module. what's causing this?
I am in the process of setting up my cDAQ9172 to run with LabView.  I have four modules installed in the chassis, including the 9201, 9211, 9263, and 9485.  I can read/write to all of the modules except for the 9485.  This module causes an error message, which I have pasted below, then causes my software to lock-up.  Same thing happens when I try to test this module in Meausrement and Automation Explorer.
I have upgraded to Windows 7 (32-bit) recently, after I installed LabView, so I wonder if this is causing the problem.
LabVIEW: An exception occurred within the external code called by a Call Library Function Node.  This might have corrupted LabVIEW’s memory.  Save any work to a new location and restart LabVIEW.  VI “GenericDIOTest1.vi” was stopped at node “ “ at a call to “daqmxcfg_DAQmx Create DO Channel (sub).vi:2”
(2,786 Views)
swithers,
Thanks for posting on the NI forums. I did not have a 9172 and a 9485 available at my desk, I can get one if I need to, but I was able to simulate the hardware within Measurement and Automation Explorer (MAX) and it did not give me any errors when I am running LabVIEW Examples. I am running on Windows 7 32-bit as well. Here are a couple things for you to try to see if we can narrow down the problem.
1) Try simulating a 9485 in MAX and run your example program with the 9485 device. If you still get the same error this could either be a problem with your install of DAQmx or with your program.
2) To figure out if this is a problem with the install of DAQmx I would recommend to try running a couple of the example programs that are designed for the 9485 device. You can open up the NI Example Finder (Help >> Find Examples) and try an example like 'Write Dig Port.vi' or 'Write Dig Chan.vi' to see if those examples give you the same error.
3) When you simulate a device, if you do not get an error from the programs it is possible that there is something wrong with your 9485 device. I would recommend trying the device on a different computer (if possible a different OS than Windows 7) and see if you can run test-panels in MAX. If you get the same results as you did with your Windows 7 machine I think we can conclude that the device is damaged in one way or another.
Let me know the results of the tests. Thanks!
Aaron W.
CLA, CTA and CPI
(2,765 Views)
