Multifunction DAQ
Labview with NI DAQ USB 6009
Newbie question - Do you have to purchase labview exclusively to start using the USB 6009 DAQ or do you get a basic version of labview to get started?
(4,094 Views)
I don't understand. You are not required to use LabVIEW with the device. The device comes with a driver that can be used with a variety of programming languages. If you are a student, you can get a student version of LabVIEW. You might also want to consider SignalExpress. I don't know if the free version is packaged with the device.
(4,088 Views)
Thanks. I didn't know the USB 6009 came with free signalexpress.
Do you know if I can configrue the USB 6009 as a counter using signal express?
(4,071 Views)
The device only has a simple event counter and it should be useable but I use LabVIEW and not SignalExpress so I can't definitely say.
(4,069 Views)
