09-11-2014 11:01 AM - edited 09-11-2014 11:03 AM
tog000 wrote:
There must be some log file or some firmware update procedure that I'm missing. Any help would be really appreciated!
I can explain a little more about how NI-DAQmx Base initializes USB devices. Perhaps with this information, you can update your Ubuntu system. Since NI doesn't have debian package installer support, you'll have to update this by hand and without NI support. If you need help, please use the Ubuntu forums and share what you've learned here; the experts over there can guide you in configuring Ubuntu USB device events.
First, why does the 6008 work while the 6218 does not?
Second, how does DAQmx Base transfer the firmware to USB devices?
The basic order of operations for RAM devices is:
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
09-11-2014 12:48 PM - edited 09-11-2014 12:56 PM
Thanks Ernesto, I know Ubuntu isn't supported, but I thought that since the 6008 worked, I assumed any others should.
Joe Friedchicken, the info you are providing is spot on. Its exactly what I needed to know to move on to try to make it work in Ubuntu.
I started investigating, and found through udev (which you mentioned, I never thought of looking in there, rookie mistake) that /etc/natinst/nidaqmxbase/bin/niusb9162dlfw is failing to run because NI-PAL never got installed correctly. Looking at the scripts, I found that /usr/local/natinst/nipal/bin/nipalkiInstallerUtility.sh didn't run because /usr/local/natinst/nipal/bin/palModuleMgr.sh was using sh instead of bash. Replaced the first line, instead of executing with #!/bin/sh
changed it to #!/bin/bash.
Now that palModuleMgr works, ran:
sudo /usr/local/natinst/nipal/bin/palModuleMgr.sh -i -o linux:dir=nipal -t kernelDriver -s demand -c -f /usr/local/natinst/nipal/src/objects/nipalk-unversioned.o
Next, /etc/natinst/nidaqmxbase/bin/niusb9162dlfw complains of a missing NiViPciK
module (I saw that one over in OpenSUSE! we are getting somewhere!)
Ran:
sudo /usr/local/natinst/nipal/bin/palModuleMgr.sh -i -o linux:dir=nipal -t kernelDriver -s demand -c -f /usr/local/vxipnp/src/objects64/NiViPxiK-unversioned.o
and then
sudo /usr/local/natinst/nipal/bin/palModuleMgr.sh -i -o linux:dir=nipal -t kernelDriver -s demand -c -f /usr/local/vxipnp/src/objects64/NiViPciK-unversioned.o
EDIT: I also ran:
sudo updateNIDrivers
And now /etc/natinst/nidaqmxbase/bin/niusb9162dlfw is running without errors. I can only hope that when I get home and connect the DAQ, the firmware will be downloaded correctly.
$ lsmod | grep "ni" nipalk 1601326 2 NiViPciK nikal 109014 1 nipalk ghash_clmulni_intel 13259 0 aesni_intel 55624 0 aes_x86_64 17131 1 aesni_intel lrw 13286 1 aesni_intel glue_helper 13990 1 aesni_intel ablk_helper 13597 1 aesni_intel cryptd 20359 3 ghash_clmulni_intel,aesni_intel,ablk_helper
I will evaluate tonight and post my results.
Could you provide me with a link to the Ubuntu NI forum to share my progress? It might help people in the same scenario.
Thanks again for all your help Joe, your explanation of how firmware is loaded was the key to moving forward with this problem.
Thanks again!
09-11-2014
01:40 PM
- last edited on
08-09-2024
12:55 PM
by
Content Cleaner
tog000 wrote:Could you provide me with a link to the Ubuntu NI forum to share my progress? It might help people in the same scenario.
I had the official Ubuntu forums in mind for questions like "how do I register a script to handle USB kernel events?"
A more targeted audience is the NI Linux User Group, where there are other Ubuntu users who share what they've learned.
Joe Friedchicken
09-11-2014 06:23 PM
Thanks Joe Friedchicken! It works!
09-12-2014 08:44 AM
Excellent 😄
Joe Friedchicken
03-11-2015 10:42 AM
Hi there, last year I was able to get NIVISA working with the USB-6218 in Ubuntu 14.04 and later. I created some instructions that I will pase bellow. I've been able to follow it and get it working on multiple machines.
PACKAGES nidaqmxbase_3.7.0 http://download.ni.com/support/softlib/multifunction_daq/nidaqmxbase/3.7/Linux/nidaqmxbase-3.7.0.iso NIKAL_140 http://download.ni.com/support/softlib/kal/1.4/NIKAL14.iso NIVISA_5.4.1 http://ftp.ni.com/support/softlib/visa/NI-VISA/5.4/linux/NI-VISA-5.4.1.iso mkdir nidaqmxbase mkdir iso sudo mount -o nidaqmxbase-3.7.0.iso iso cp iso/* nidaqmxbase -Rv sudo umount iso cd nidaqmxbase sudo alien --target=x86_64 -k --scripts labview-2012* nidaqmxbase-cinterface* nidaqmxbase-labview2013* nidaqmxbase-board-support* nidaqmxbase-common* nidaqmxbase-usb-support* ** PATIENCE ** sudo dpkg -i *.deb mkdir nikal sudo mount -o NIKAL14.iso iso cp iso/* nikal -Rv sudo umount iso cd nikal mkdir tar cd tar tar -xf ../nikal-1.4.0f0.tar.gz cd rpms sudo alien --target=x86_64 -k --scripts *.rpm ** This is the nivisa dir from NIVISA_5.4.1.ISO, not the one included with nidaqmxbase ** mkdir nivisa sudo mount -o loop NI-VISA-5.4.1.iso iso cp iso/nivisa-5.4.1f0.tar.gz nivisa cd nivisa mkdir tar cd tar tar -xf ../nivisa-5.4.1f0.tar.gz cd rpms sudo alien --target=x86_64 -k --scripts *x86_64.rpm sudo alien --target=x86_64 -k --scripts nivisa*.rpm sudo alien --target=x86_64 -k --scripts *noarch.rpm #**IMPORTANT** rm nikali*deb cp ../../../nikal/tar/rpms/*.deb . sudo dpkg -i *.deb sudo updateNIDrivers sudo modprobe nikal ** disconnect USB DAQ, reconnect ** nidatalogger
04-10-2017 07:02 PM
Why not ? Debian packaging is pretty trivial. And you always should build everything for the target distro anyways (otherwise there easily can be subtle mismatches eg. on shared libraries, etc !)
- For flash devices like the 6008, the firmware update utility can reprogram the flash -- /usr/local/natinst/nidaqmxbase/bin/FWUpdate
- For RAM devices like the 621x, a different utility is used when the kernel reports a new attached device -- /usr/local/natinst/nidaqmxbase/bin/niusb9162dlfw
Why aren't you just directly using the Linux firmware loader infrastructure ?
- I suspect this is where the problem is for you. Either alien incorrectly translated the scripts or Ubuntu has a newer interface for controlling udev or Ubuntu isn't using udev and instead has a different kernel event messaging system.
Ubuntu *is* using udev in a pretty standard setup. You just have to place your rule files into the usual /lib/udev/rules.d/ directly. I wonder whether you ever read the manpages carefully ... 😮
- The nidaqmxbase-usb-support RPM also includes udev rules to react to the insertion and removal of NI USB devices -- /usr/local/natinst/nidaqmxbase/etc/hotplug/usb
- The post-installation script in the RPM also creates symlinks and reloads the udev rules.
Why so complicated ? The package is supposed to put its rule files into /lib/udev/rules.d/ - that's all.
For both types of devices, since the firmware is transferred from the host to the device, it must be kept on the host -- /usr/local/natinst/nidaqmxbase/bin/support
Use the Linux firmware loader infrastructure. Firmware binaries shall be placed at /lib/firmware/
Anyways, /usr/local/... shall *never* be touched by *any* package - it's reserved for manual (self-compiled) installs.
If a vendor prefix is needed - /opt/<vendor>/ is the right place.
Did you folks ever read the FHS and LSB spec ?
