07-08-2016 07:53 AM
07-12-2016 08:16 AM - edited 07-12-2016 08:28 AM
Just some assumtions:
1. the sensor has an internal switched power supply (needed if only a single ground reverenced DC supply is provides but the output is +-5V 😉 )
2. this switched powersupply introduce current spikes on the supply lines
3. supply lines are resistive ! (incl. the ground line in this case, and see my signature :D)
4. the current spikes on the ground supply line are also measured since you shared this line 🙂
(Or you have a powersupply nearby that couple these spikes into your cable/sensor)
Possible solution: seperate the signal and power supply lines. two twisted pair should do the job. connect the A0- as close as possible to the load cell output. try to avoid a shared power supply and signal line)
If you can't seperate them because of a fixed cable (hard wired to the sensor and no seperate ground provided) claim/hit the sensor maunufactor (BTW a link to the sensor datasheet would have helped 😉 ) and try software filter.
Software filter:
Lowpass filter always help , thats what the DMM do 😉 , for small spikes and higher bandwidth median filter migth do the job.
As more as you (and we!) know about the signal provided and the information needed (How fast is the signal changing, how fast do you need that information... also called needed bandwidth 😉 ), as better the software filter can be matched.
Sample the signal (with and without load) with a higher samplerate (seems like you have a 60Hz powerline and the spikes are every 1/60, so it could also be a poor designed classical powersupply involved) 10kSPS (or 100kSPS) for 120ms are fine. and post a png and a vi including a graph with save data if you want to motivate others to provide a filter.
