07-06-2017 04:07 PM
Background: I'm trying to configure NI's new NIDAQmx library for Python to record 6 analog voltages with a USB-6210 DAQ. Here is my working baby code:
############################################### # import libraries import time as t import numpy as np import nidaqmx import pprint fSampling = 1.0 #Hz nSamples = 5 #samples pp = pprint.PrettyPrinter(indent=4) dtMax = 15 #sec ############################################### # DAQ # config with nidaqmx.Task() as task: t1 = t.time() task.ai_channels.add_ai_voltage_chan("Dev1/ai0:5") task.timing.cfg_samp_clk_timing(fSampling) t2 = t.time() dt = t2 - t1 while dt < dtMax: data = task.read(number_of_samples_per_channel=nSamples) t2 = t.time() dt = t2-t1 print dt pp.pprint(data) ############################################### # output to file
And here is its output:
4.04500007629 [ [ 5.450821630953765, 4.550910274171798, 3.375039902877309, 2.8346332012577977, 2.575119650469254], [ 0.1436219369816977, 0.1452665056820444, 0.14444422133150514, 0.14378639385160064, 0.1442797644614851], [ 0.42056734692955455, 0.42155408844033515, 0.421225174603295, 0.421389631521801, 0.4208962607663682], [ 0.1837494141045311, 0.1845716984899678, 0.1842427847357057, 0.18407832785861833, 0.18358495722753115], [ 0.3126836145923778, 0.3133414421913342, 0.313176985291552, 0.31284807149207383, 0.31284807149207383], [ -0.344814834975827, -0.34399255107332927, -0.34465037819538946, -0.344814834975827, -0.34465037819538946]] 9.05099987984 [ [ 2.4391135199034384, 2.3614897130805055, 2.314454951111576, 2.284359282671887, 2.2605129885258157], [ 0.14460867820155443, 0.1436219369816977, 0.145102048811878, 0.14493759194174088, 0.1429641095023787], [ 0.42106071768481745, 0.4207318038479473, 0.42204745919610764, 0.42155408844033515, 0.42056734692955455], [ 0.1837494141045311, 0.18358495722753115, 0.1845716984899678, 0.1847361553671425, 0.1837494141045311], [ 0.3121902438934617, 0.3121902438934617, 0.3133414421913342, 0.3123547007930717, 0.31284807149207383], [ -0.34563711887755055, -0.34563711887755055, -0.34465037819538946, -0.344814834975827, -0.34465037819538946]] 14.0550000668 [ [ 2.243573897101991, 2.2325552649417535, 2.2231812048235535, 2.215616173903215, 2.2082156002220095], [ 0.14411530759149432, 0.14411530759149432, 0.14493759194174088, 0.14559541942246498, 0.14411530759149432], [ 0.42007397617454656, 0.421225174603295, 0.42171854535889763, 0.42188300227748843, 0.42056734692955455], [ 0.18309158659670616, 0.18407832785861833, 0.18440724161282218, 0.1845716984899678, 0.18342050035056034], [ 0.3120257869938804, 0.31284807149207383, 0.3133414421913342, 0.313176985291552, 0.3120257869938804], [ -0.34497929175623365, -0.34514374853660934, -0.34382809429273675, -0.34465037819538946, -0.3454726620972678]] 19.0509998798 [ [ 2.2034463416511727, 2.1991704546724478, 2.1955523964713692, 2.1930855386131443, 2.186836165394627], [ 0.1442797644614851, 0.14477313507163303, 0.14477313507163303, 0.14477313507163303, 0.14378639385160064], [ 0.42040289001119024, 0.42188300227748843, 0.42221191611475506, 0.421389631521801, 0.42007397617454656], [ 0.18342050035056034, 0.1850650691215794, 0.1845716984899678, 0.1845716984899678, 0.18325604347361868], [ 0.3121902438934617, 0.313505899091145, 0.313176985291552, 0.31284807149207383, 0.3121902438934617], [ -0.34530820531695405, -0.34382809429273675, -0.344814834975827, -0.3436636375121134, -0.34563711887755055]]
Questions:
Thanks!
07-07-2017 11:09 AM
DAQmx does not timestamp samples when they are taken on the DAQ device, but it does when it reads the FIFO samples onto the computer if you are reading in a waveform data type. I would check the documentation to see if that is implemented in the Python version.
As for timing, if you implement the same code in LabVIEW does it take the expected time?
07-07-2017 03:09 PM
The documentation for NI's NIDAQmx Python library is sparse at the moment--NI released this library less than 2 months ago--so I haven't had much luck there.
As for a LabVIEW comparison, I cannot do that because I simply don't have access to LabVIEW right now...hence Python.
07-07-2017 03:23 PM - edited 07-07-2017 03:26 PM
At any rate, my current solution to problem 1 (timestamps) is to just append the time of buffer-reading to my data array during data-acquisition. In post-processing, I will interpolate the time between the samples using the timestamps and my sampling period. Is there a more exact way, or is this how the timestamp for each sample of the dynamic datatype is created in LabVIEW?
data-acquisition:
T = sampling period
N = buffer size, N = (samples/(channel*sec)) * T
data array
t0 ch0 ... ch5
- s1 s1
- s2 s2
t1 sN sN (buffer read)
- sN+1 sN+1
- sN+2 sN+2
t2 s2*N s2*N (buffer read)
Post:
file output
t0 ch0 ... ch5
t+T s1 s1
T+2T s2 s2
t1+T sN+1 sN+1
t1+2T sN+2 sN+2
07-10-2017 05:10 PM
Hey aeroAggie,
What you are doing is basically how we do timestamps in LabVIEW. Our DAQ cards do not have a time stamp mechanism, so we use the t0 and dt in LabVIEW to time stamp it.
For this, it looks like your method is the most exact way to do it.
07-10-2017 09:32 PM
4.04500007629 [ [ 5.450821630953765, 4.550910274171798, 3.375039902877309, 2.8346332012577977,Questions:
- Does DAQmx make a timestamp for each channel's sample, or do I have to interpolate my own timestamp between each loop iteration?
If DAQmx does generate a timestamp for each sampling, how can I access it?- Why does it take less than 5 seconds to collect data for the first iteration? I feel like there's a simple logic error in my code, but I just can't figure it out even after a lot of dummy prints
T_loop = nSamplesPerChannel/fSampling (5/1 = 5)Thanks!
1 Yes you have to add dt to t * Sample index
2. Because sample 0 is a T=0, 2 is at T 0+1 ,etc So the first read returns at 4 * Sample rate + some startup for the first conversion. On subsequent reads, the first sample in the read cannot start until a sample period has passed from the last sample so they take longer.
07-11-2017 07:47 AM
OOHHHHHH, so it's like this:
sample/dt from t = 0
1/0
2/1
5/4 - READ
6/5
7/6
10/9 - READ (9-4 = 5)
That makes sense. I should have tried listing or acting out the data-acquisition. Thanks!
07-11-2017 08:07 AM
With humorous intent You could have worked it out on your fingers Place your left hand on the table and start with your right index finger on your left thumb the samples are taken when your index finger moves to the next finger and the intervals are the time between fingers. The read occurs when you touch your pinky.
07-11-2017 08:09 AM
NI should start with that for its DAQ bootcamp
08-21-2018 05:56 AM
Hi aeroAggie,
How would you include the sampling time you calculated to the logfile?
