Multifunction DAQ
Maximum/Minimum input range parameters for DAQmx Create Channel (AI-Bridge) VI
I have a question regarding the max/min input range in DAQmx Create Channel (AI-Bridge) VI.
I have the PXIe-4330 card and it's maximum input signal range, without custom scaling, is ±25 mV/V.
In the DAQmx Create Channel (AI-Bridge) VI, I specify the unit as mV/V.
If I want to configure the max/min input range for this channel = 10 mV/V, what should be the value entered in for these parameters – Is it ±10 or ±0.010 (since the unit is already specified as mV/V in the VI)?
I attach the snapshot of the VI for reference.
Thanks for your help,
Pham
(4,263 Views)
Accepted by TEmember
Hey Pham,
That value is in mV/V, so +/- 10 mV/V should be appropriate.
Matt W.
Applications Engineer
(4,216 Views)
