Measuring frequency on DAQmx analog input
I have an analog pulse (amplitude varies) connected to my USB-6212 DAQmx device.  I am looking for a way to measure the frequency of the signal.  So far, I have found no DAQmx-supported method for doing this.  I am coding in LabVIEW and the only way I have found to do it is by writing my own code to perform signal analysis of the amplitudes to determine the half-max level to find the rising and falling edges in order to count pulses to derive frequency.  Somebody please tell me there is a better way.  I need help on this one guys.
(3,801 Views)
Accepted by kc64
With an analog capture, you can try the Extract Single Tone Information function on the Signal Processing>Waveform Measurements palette. There's also the Tone Measurements Express VI.
(3,797 Views)
Dennis--
Thank you very much.  I'm sort of embarrassed I never recognized that pallette was even there.  Those VIs are going to help me a lot.
kc64
(3,755 Views)
I am looking for the Tone Measurement vi but, I get an error message that says "Object Not Found".  Is Signal Express an add-on that must be purchased?  I have the Labview Base Development system, version 11.0, 32-bit.   What do I need to do to get this function?
Dave
(3,170 Views)
