Missing DAQ Assistant LV2009 student edition
Yep, that worked...you da man!
Message 11 of 25
(2,709 Views)
Sir,
I have installed DAQmx 8.9.5 and Labview 2010 in my system and i am unable to find daq assistant in express palette and measurement i/o palette
please help.
thank you
Message 12 of 25
(2,557 Views)
In order to use NI-DAQmx with LabVIEW 2010, you will need to use a compatible version of NI-DAQmx.  I recommend NI-DAQmx 9.3, the latest version.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 13 of 25
(2,552 Views)
Is this NI DAQmx required to run LabVIEW? Can we use LabVIEW without installation of NI DAQmx?
What's the use of NI DAQmx?
Message 14 of 25
(2,367 Views)
Of course it's not required for LabVIEW. It's required for DAQ devices from NI. There are numerous pages about DAQmx. Did you do any search?
Message 15 of 25
(2,363 Views)
Hi Sir
I'm using labview 2010 and DAQ 9.6.1
Yet, the daq assistant did not show.
I use win 7, 64bit. labview 2010 might be 32bit.
wei shen
Message 16 of 25
(1,711 Views)
Does it show up in MAX? Did you install it after LabVIEW?
Message 17 of 25
(1,707 Views)
It shows in MAX. Yes, I installed before labview
wei shen
Message 18 of 25
(1,700 Views)
And as stated earlier, you did the installs in the wrong order. The DAQmx installer cannot install support for something that is not there.
Message 19 of 25
(1,692 Views)
Resolved.
wei shen
Message 20 of 25
(1,687 Views)
