Multiple Finite Analog Inputs from Multiple Triggers - Error -50103 "The specified resource is reserved"
@Ibboh wrote:
- The minimum time between the last sample in one data set and the trigger of the next is 0 ms.  In fact the next trigger can occur during the sampling of the first dataset as the two are independent.
That is why you either need a second DAQ board or acquire everything continuously (your 100kS/s should be find) and have seperate loops to get only the data you care about out of the waveforms.
GCentral
Message 11 of 13
(2,117 Views)
I agree. With the timing you have indicated you will inevitably get a conflict about which data belongs with the other.
You should be able to extract 1000 sample segments from a 100 kS/s data stream and discard the rest without too much trouble if you decide to go the continuous sample route.
Lynn
Message 12 of 13
(2,110 Views)
OK,  Thanks for the suggestions.  I will look into implementing continuous acquisition and see how it goes.
Message 13 of 13
(2,083 Views)
