02-20-2019 09:32 AM
It looks like my NI 9205 module broke. At least it is not recognized anymore when I check in NI MAX (Version 17.5.0f0). The chassis is NI cDAQ-9185.
I don't know if there is anything I can try, it worked until now. All the other modules (including another NI 9205) work just fine. I also tried another chassis (NI cDAQ-9184) to no avail. Any suggestions are welcome. Thanks
02-21-2019 02:43 AM
Hi gagamehl,
there are multiple things you may check before sending the device for a repair. I would start in this order:
This error message is returned because the NI Device Loader Windows Service (or 'nidevldu') is not running.
To properly start the service and ensure that the service is always started at startup follow these directions:
Go to Start » Control Panel » Administrative Tools » Services
Right click on NI Device Loader Service (may be listed as 'nidevldu')
Select Properties
Set the startup type as Automatic
Click the Start button.
please follow the instructions and tell me if they were helpful.
Best,
Andrzej
