Multifunction DAQ
NI 9237 Quarter Bridge Absolute Accuracy
Given a NI 9237 Bridge Completion Module with NI 9944 Accessory Terminal and 120 ohm strain gauges with GF = 2.11, how do we calculate strain accuracy?
I was told that the absolute accuracy for quarter bridges is given by
Absolute Accuracy = (Gain Error * Reading) + (Offset Error * Range) + Noise + Half Bridge Tolerance + Quarter Bridge Tolerance.
Since I'm using the NI 9944, the Quarter bridge tolerance would be 500 uV/V (given by NI R&D). The Half Bridge tolerance is given in NI 9237 manual to be 1.2 mV/V.
1) There are no Input "Noise" values for quarter bridges in the NI 9237 manual; do we just use the half bridge noise?
2) If I am using a sampling rate of 1.613 kS/s (the lowest valid sampling rate for NI 9237) and my system is still in its 1st year of usage, is my gain error still 0.05%? It's noted that 0.05% applies to 50 kS/s; if the gain error doesn't apply at my low sampling rate, how do I find the gain error?
3) If my maximum/minimum strain measurements are +/-600 ue (microstrain), how do I change my "Reading" and "Range" values in the absolute accuracy equation above, if they need to be adjusted?
4) Why does the absolute accuracy for a quarter bridge set up include half bridge tolerance?
5) Is the equation for conversion of voltage accuracy to strain accuracy for quarter bridge, , where U is the voltage accuracy given by the absolute accuracy equation above.
Sample calculation using the following assumed values for quarter bridge:
Gain Error/Offset Error = 0.05%
Reading/Range = 25 mV/V
Half Bridge Noise = 1.6 mV/V * 3
Half Bridge Tolerance = 1.2 mV/V
Quarter Bridge Tolerance = 500 uV/V
Absolute Accuracy = (0.0005*.025 V/V) + (0.0005*.025 V/V) + ((1.6E-6)*3 V/V) + (1.2E-3 V/V) + (500E-6 V/V) = 25 mV/V +/- 1.73 mV/V
Strain Accuracy = -4(V/Vex) / GF(1+4(V/Vex)) = -4*(25 mV/V +/- 1.73 mV/V) / (2.11)*(1+4*(25 mV/V +/- 1.73 mV/V))
How would I simplify this strain accuracy to get a reading +/- range of accuracy?
Thank you for any help.
(4,985 Views)
I'll do my best to answer your questions.
If you look on page 8 of the device operating instructions and specifications document you'll find that the NI 9944 completes the half bridge.  So yes, you will use the half bridge noise.
This applies at a data rate of 50 kS/s. Lower data rates can have up to 0.20% of reading additional gain error.  This can be found on page 24 of the device operating instructions and specifications document
The reading will be a particular value for the sensor and the range will be the range of voltage for the device.
4)Why does the absolute accuracy for a quarter bridge set up include half bridge tolerance?
I believe the response for number two will answer your question.
Yes, I believe this is the correct equation.  Please let me know if you have any further questions.
-Joe
(4,948 Views)
Hi Joe,
Thank you for responding and answering most of my questions!
Do you happen to know how to calculate what Percent of Reading (Gain Error) I would get depending on what sampling rate I use? Otherwise, I guess I could use the 0.20% gain error as a worst case scenario.
This is more of a math question - since U will be in the form of a reading +/- a range, (e.g. 25 mV/V +/- 1.73 mV/V), do you know how I would simplify or interpret the strain accuracy after substituting in the value for U?
(4,941 Views)
Accepted by Clu1992
Yes,  I would calculate the Gain Error for a worst case scenario (0.2%)
Just use the worst case scenario again to calculate for both positive and negative values regarding 1.73mV.
-Joe
(4,893 Views)
