04-27-2016 10:42 AM
Hey guys,
I'm looking for a solution to a problem. I'm interested in purchasing an Analog Out for a vibration analysis system. My frequency range is 10-120hz and my output range is 10mV-20v.
The 9263 is a 16bit module, +-10v, with a 14mV accuracy specification. I need to be able to output 10mV as my minimum output. This board ALMOST does it, but not quite.
Can anyone point me in the right direction with this? I've contacted NI support and one of their engineers is looking into it, but he said to search for solutions on my end.
Is the range static on these modules, or can they be changed? IE: +-5v. Can I do some attenuation to get the desired 10mV minimum?
Any help with this is greatly appreciated.
04-28-2016
07:54 PM
- last edited on
01-10-2025
05:13 PM
by
Content Cleaner
Hey glskinner84,
If you are looking for a range from 10mV - 20V you probably will not be able to all in one configuration without any external circuitry. This is because in order to get these ranges that would go beyond the specification.
If you want to check on what you can set on these modules I might try simulating the module, running your application and seeing if any errors are thrown.
NI-DAQmx Simulated Devices - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0PxCAI&l=en-US
One idea to get around this is to use the NI 9269 (maybe with an external summing amplifier) and multiple channels (since this module is simultaneous and differential so you can stack them).
