NI 9265 Compliance Voltage
Can anyone give me a decent reason why the compliance voltage on the NI 9265 is only 12V, but you can supply the card with 9-36VDC?  The process control industry would REALLY love to know if there is any chance of updating this someday.
(5,445 Views)
The compliance voltage is 12V because the output load is rated to a max 600 ohms.
I would assume this is set with respect to the characteristics of the DC-DC converter and finding one with clean enough regulation to support a 16bit ADC so that sub-microAmp precision is achievable.  But I had no hand in the design considerations.
"Should be" isn't "Is" -Jay
(5,443 Views)
Jeff, that all makes absolute sense, and I'm sure those were the considerations.  tradeoffs have to be made.  I just happen to know some fairly large companies, and a few small ones (Iike JET) that are finding this to be an issue.  I'm having issues powering a valve via 9265 and being able to use a HART modem with it, and I'm not the only person.
(5,441 Views)
Accepted by kent.wedeking
That may be an issue for the Idea exchange.  I could see where trying to power multiple devices from a single loop could require a higher compliance voltage.
The distributed system you allude to does seem like an interesting challenge.
(5,433 Views)
Thanks Jeff!  Yes, a challenge would be one way to describe it.  I think its about to get a push on it from a lot of us around about August time 😉
(5,430 Views)
