02-02-2015 08:29 AM
So I'm using a NI 9269 for generating DC voltage. For the a01 and a03 channels, my outputs are offset by 13.68 V. Is this some kind of calibration issue? If so, how do I rectify it?
A R
02-02-2015 01:59 PM
Is it truely an offset or is that just the maximum it can go to? Like if you told it 5V it goes to 18.68V.
My first thought is that this is a grounding/wiring issue. After that, I would say there is something wrong with your module and you should call up your local NI rep and ask them what can be done for repair and/or swapping out modules.
02-02-2015 06:18 PM
What's it powered off of? Sounds strangely close to automotive charging voltage.
For starters I'd say check the connections and grounds.
02-02-2015 06:41 PM - edited 02-02-2015 06:42 PM
Yup it's a true offset. If i set it to 5V it goes to 18.68, set to 10 I get 23.68 (although the limit of the device is +/- 10V).
02-02-2015 06:42 PM
It's powered off of USB through the cDAQ chassis.
02-02-2015 08:20 PM
02-03-2015 07:19 AM
Then you have a wiring issue. Do you have a diagram of exactly how you have it wired up?
02-03-2015 08:36 AM
@crossrulz wrote:
Yup it's a true offset. If i set it to 5V it goes to 18.68, set to 10 I get 23.68 (although the limit of the device is +/- 10V).Then you have a wiring issue. Do you have a diagram of exactly how you have it wired up?
The wiring isn't too complicated. The module is used to generate DC voltage. There is + and - terminals. I have these hooked up directly to the DMM.
02-03-2015 09:01 AM
02-03-2015 09:17 AM
@Dennis_Knutson wrote:
If it's not that complicated, why can't you attach the diagram? You said you were using multiple modules and its important to know if you've somehow connected one to another. This is a simple request.
I didn't attach a diagram cuz I didn't see how it would help. Essentially, the four channels are used as four different voltage sources. They are not connected together.
