NI PCI 1409 PCI 6025E
Hi Friends,
I have NI PCI 1409 (image interface) and PCI 6025E (DAQ) boards installed on windows xp desktop
 which connected to Mikron inferred camera (M9104).
Recently I upgrade my labview to 8.6.
After the upgrading, the setup software of Mikron camera didn't work.
Is anyone has experience to solve the problem?
Any suggestion are highly appreciated.
Jack
(3,289 Views)
Accepted by topic author jackp6
Hi jackp6,
I believe your issue pertains to drivers.  After upgrading to LabVIEW 8.6 did you upgrade your NI-IMAQ drivers as well?  According to our IMAQ and IMAQdx Compatibility Chart you must have versions 4.1 or higher for NI IMAQ and 3.2 or higher for NI IMAQdx.  I would suggest a full reinstall of our Vision Acquistion Software which includes these drivers.
Lynn
Senior Systems Engineer
(3,263 Views)
One more addition - you will also need to reinstall your DAQ drivers to use the PCI-6025E.
(3,262 Views)
Hi
Thanks for the help.
The problems are solved.
Reguards,,
Jack
(3,239 Views)
