05-05-2010 10:42 AM
Hi Seth thanks for your response. I only see the backplane (all the modules are plugged in).
05-06-2010 09:55 AM
Just to check, if you remove a module from the chassis and plug it back in, the new hardware wizard does not come up, correct?
Also, is the chassis plugged directly into the computer, or are there any hubs, extenders, or switches in use? And we aren't doing any kind of virtualization, like VMWare, correct?
05-07-2010 12:56 PM
05-08-2010 10:33 PM
I just noticed I'm getting an NI error at boot. Checking online for a solution doesn't appear to do anything.
05-10-2010 08:51 AM
05-10-2010 10:29 AM
This is certainly a strange issue, you have our developers a bit stumped. In an effort to un-stump them, there is some more information that I'd like to get. I apologize for all the back and forth we've needed.
Here's what we need:
A screenshot of my Device Manager windows sorted by connection is attached below for reference:
12-13-2012 05:19 PM
found the solution? I have same problem, I can see the chassis but not the modules on Device Manager windows. On MAX happens the same.
12-14-2012 05:50 PM
Hi mdelsol,
Have you attempted the solutions posted earlier in the thread? I would recommend trying to clear a possible MAX database corruption. The steps for doing this are outlined in this article. I hope this helps!
12-17-2012 02:26 AM
Hi, we tried everything posted on this thread and others. We think that problem is on windows because it doesn’t recognize the modules on Device Manager. We expend around two days uninstalling and installing again different NI drivers and programs, repairing MAX database, etc... and nothing. Only way we solved the problem was installing windows again keeping programs and users configurations. So I strongly recommend everybody having same problem to reinstall windows as will save a lot of time to finally do so.
Marc.
09-17-2013 08:58 AM
I'm having the same problem. I even added a simulated cDAQ-9174 in MAX, but if I try to add modules to it, it hangs, and self-tests throw an error. I tried everything in this thread, and I'm down to just formatting the machine now. This is not an acceptable solution.
A MAX technical report is attached.
-Mark
