Multifunction DAQ
Need help on error: libnipalu.so failed to initialize
Sorry..i am new to this forum...tot someone wud help me for sure with the issue..will nt do it again..thnks
Message 11 of 16
(2,092 Views)
Can someone tell me how to start a new thread?
Message 12 of 16
(2,089 Views)
Hi larshana-
     To create a new thread, just click on the forum name at the top of the page to view all the threads in that forum.  There is a big blue button at the top of that page that says New Message.  Click on that to create a new thread.
Gary P.
Message 13 of 16
(2,064 Views)
Thanks a lot guys.! I too had the same problem of 4GB RAM and the libnipalu.so error. At boot i typed mem=4096M and it worked. But i have a question, do i have to give the dynamic mem assignment to 4GB each time during boot?
Message 14 of 16
(1,967 Views)
Rakhi-
     You may get some better answers if you post to the NI-DAQmx Base Forums.  Just an idea.
     Have a great day!
Gary P.
Message 15 of 16
(1,954 Views)
Linux of course support PAE (Physical Address Extentions) that allows up to 64 GB of physical address space.  In general this breaks a lot of assumptions in a driver written for a 32 bit operating system,
No, it breaks the assumption of a driver written for some specific (sub-)architecture, that doesn't use the proper APIs, which have been created to solve exactly that type of problem.
Will we remove this requirement in the future?  Anything is possible, however porting our drivers to 64 bit Linux is probably more likely since it provides the same benefits and is the direction the computer industry is heading.
If it's such bad code, that it even doesn't use the DMA API correctly, than it's better - and cheaper - to rewrite it from scratch. This time, as an IIO driver, of course.
Linux Embedded / Kernel Hacker / BSP / Driver development / Systems engineering
Message 16 of 16
(1,074 Views)
