02-04-2015 09:07 AM - edited 02-04-2015 09:08 AM
Thank you all for the input.
Dennis - I'm creating the .vi for someone else. I don't know how it will be used, I just have the specs for what they want it to do.
crossrulz - I actually tried creating a parallel logger with "Write to Spreadsheet" in the same While Loop that houses the waveform reader. The issue I had there is that they were out of sync and I would only get one of the sample bunch so the timestamp I put in wouldn't even match the reading.
deppSu - Could you please elaborate on what you mean by programming the time information in with LabVIEW? I know I have the option of creating the time column myself in Excel but I wanted to make this feature automatic using LabVIEW.
Thanks again for all your suggestions,
Yusif Nurizade
Edit: Spelling and grammar.
02-04-2015 09:29 AM
03-24-2015 12:56 PM
Forgive me, I thought I replied to the latest posts. Better late than never I suppose.
I played around with the LabVIEW code and couldn't come up with an efficient way to add in the column I wanted. Manually adding a column using the start time and interval seems like the simplest way to achieve my pupose so I will stick to that for now.
Thanks very much for the advice,
Yusif Nurizade
