05-31-2011 03:22 AM
Hi
I have two different signal that is Ch1 and Ch2
Then I used Normalize Waveform vi to tranform the waveform data so that its maximun is 1 and its minimum is -1 just like the signals below.
Supposely when I divide this two signal, I should have an output like signal below
but what I get is like this signal below
Why is this happen? I attached the VI here
06-01-2011 01:49 PM - edited 06-01-2011 01:51 PM
Hey yusof,
You are dividing by zero at the points where it diverges. Otherwise, it just fluctuates between 1 and 1 which is likely just due to quantization. Hope that helps!
11-22-2011 10:08 AM
it helped a lot sir, thanks
11-23-2011 10:11 AM
No problem.
