Multifunction DAQ
OMRON E5CC,error S.ERR after adjust
Hello everyone,my problem is related to Digital Temperature Control OMRON E5CC,at my workplace I had some problems with one of the furnaces I wanted to fix,I wanted to correct against another device that we check the temperatures and too much zeal in the protected area, but I did not give up, I passed passwords (cmoV with password 1201) I reached adj 30, where I followed the steps and I managed to decalibrate it.Now I'd be glad if I could get to the factory settings.use a temperature sensor type J (-200 to 1300),today I will try with a PT100 sensor.I would like to get some advice or opinion about on how to recover the Omron device. Thank you in advance.
(8,786 Views)
Hello Korbw,
Your question does not really address a specific NI product, hardware or software, could you let us know if you are using or need specific help with any NI product? Also, here is a forum post related to your device:
https://forums.ni.com/t5/LabVIEW/Omron-E5CC-Temp-Controller-Modbus-Reading-Registers/td-p/3610919
Perhaps this post can be helpful.
(8,753 Views)
