03-03-2014 05:03 PM
Is it possible to use the PCI-DIO-32HS with Windows 7? If yes, can you direct me to the correct driver to install?
Thank you.
Solved! Go to Solution.
03-04-2014 09:47 AM
Hi aaron.cramer
There is a Traditional DAQ driver for Windows 7. The driver does not work for 64-bit operating systems.
This link describes the limitations of the driver and links to the download: http://digital.ni.com/public.nsf/allkb/8EC9E81C3DE4E619862573930083BD7A
03-28-2014 03:28 PM
Board works under DAQmx, 64 bit Win7
