01-20-2016 10:31 AM
Hi y'all,
We want to change our design to use PCIe data acquisition card since we had some USB driver issue in the past. Is the PCIe-6321 a good match to replace the USB-6211-OEM acquisition card?
Are there better alternative?
Fabrice
01-21-2016 02:40 PM - last edited on 11-27-2024 04:55 PM by Content Cleaner
Hello Fabrice,
Thank you for taking an interest in our PCIe line of DAQ cards. I've taken a look at the USB-6211-OEM and the PCIe-6321 to see if they are similar in specifications and capabilities. I would say that the 6321 is a good match to replace your current USB card. As long as you intend to not use more I/O lines than intended or exceed the designated sampling speed then it should be a good replacement.
If you need high-speed sampling or more I/O lines for various tasks then another card may better suit your needs.
The resource below compares several of our X Series devices (USB and PCIe).
What is NI X Series? - 1. Product Overview
These links may also prove helpful during your upgrade:
Major Differences Between E Series, M Series, and X Series NI DAQ Devices
NI X Series Upgrade Guide (from USB to USB devices however)
Alex C.
01-21-2016 04:18 PM
Thanks for your reply Cicco
